Odoo中文社区可以通过以下三个域名访问:shine-it.net , odoocn.org,odoo.net.cn
原论坛用户的基本信息和发帖这里都予以保留,请注意:原论坛用户无需重新注册新用户,但是您的密码需要重置
如果您登录系统碰到问题,请在微信公众号留言:
Problem with setting up Subcontracting Manaufacture
  • Hi, I have a question regarding subcontracting manufacture.....
    Usually, we will send several parts to supplier and request for external engineering with formal Puchase order. Once we receive the completed parts from supplier, we will assemble the parts with other parts as further steps to complete the customer order. To make it clearer, there is sample:
    Customer orders Product A
    We need Product B and C to make 1 A;
    and we will provide suppplier product D to make a Product B firstly (a purchase order is requested)
    Therefore, in our case, how should we set up the products A-D? and how is the location/BOM/routing? I tried to follow manual but there is no internal move or Purchase order showing out.
    Any help is appreciated.
    Thanks
    Thanks
  • 哦,把D的生产库位设置为供应商库位应该就能根据mrp自动生成送货单了。
    只是采购件B下面再挂子件不太符合BOM的逻辑,不知道mrp运算会不会考虑这一点。如果算不出来可能要把bcd放在同级。
    总之,可以实现。
  • Hi, thank you for help.
    I tried BOM, it works but there is no internal move shown as mentioned in OPENERP's user manual.that's why I try to do further.
    our company's manufacturing is a bit complicated.
    Sorry for not typing Chinese here. No Chinese typing in my office computer.
    Thanks again.
  • 管理员
    Hi clairekn,
    I copy and paste below the setup process for subcontracting manufacturing in openerp from OpenERP  user manual , let us know if you are still facing problems:
    Subcontracting Manufacturing  In OpenERP it is possible to subcontract production operations (for example, painting and item  assembly) at a supplier’s. On the relevant routing document, you have to indicate a supplier  location for stock management.
    You then have to configure a location dedicated to this supplier with the following data:
    [list]
    [li][i]Location Type[/i]: Supplier,[/li]
    [li][i]Location Address[/i]: Select an address of the subcontractor partner,[/li]
    [li][i]Chained Location Type[/i]: Fixed,[/li]
    [li][i]Chained Location If Fixed[/i]: your Stock,[/li]
    [li][i]Chaining Lead Time[/i]: number of days before receipt of the finished product.[/li]
    [/list]  Once the manufacturing has been planned for the product concerned, OpenERP will generate the  following steps:
    [list]
    [li]Delivery of raw materials to the stores for the supplier,[/li]
    [li]Production order for the products at the suppliers and receipt of the finished products in the stores.[/li]
    [/list]  Once the production order has been confirmed, OpenERP automatically generates a delivery order to  send to the raw materials supplier. The storesperson can access this delivery order using the menu  [i]Warehouse ‣ Warehouse Management ‣ Internal Moves[/i]. The raw materials will then be placed in  stock at the supplier’s stores.
    Once the delivery of raw materials has been confirmed, OpenERP activates the production order. The  supplier uses the raw materials sent to produce the finished goods which will automatically be put  in your own stores. The confirmation of this manufacturing is made when you receive the products from  your supplier. At that point, you indicate the quantities consumed by your supplier.
      Tip
    Subcontract Without Routing
    If you do not use routing, you can always subcontract work orders by creating an empty routing in  the subcontract bill of materials.
      Production orders are found in the menu [i]Manufacturing ‣ Manufacturing ‣  Manufacturing Orders[/i]. A production order is always carried out in two stages:
    [list type=decimal]
    [li]Consumption of raw materials.[/li]
    [li]Production of finished products.[/li]
    [/list]  Depending on the company’s needs, you can specify that the first step is confirmed at the  acknowledgement of manufacturing supplier, and the second at the receipt of finished goods in the  warehouse
  • Thank you very much.
    I think I sort of get that problem solved......
    I may have more questions later, hehe.....
    Thank you again.
    Have a good weekend. ;D
与 Odoo 中文社区 的连接断开,我们正在尝试重连,请耐心等待
