  4. OE V6.1.1 oecn_base_fonts 配置新字体错误
2 帖子 1 发布者 2.3k 浏览 1 关注中
    syman_li
    Client Traceback (most recent call last):
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/common/http.py", line 180, in dispatch
        response["result"] = method(controller, self, **self.params)
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/controllers/main.py", line 1052, in call_button
        action = self.call_common(req, model, method, args, domain_id, context_id)
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/controllers/main.py", line 996, in call_common
        return self._call_kw(req, model, method, args, {})
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/controllers/main.py", line 1010, in _call_kw
        return getattr(req.session.model(model), method)(*args, **kwargs)
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/common/openerplib/main.py", line 250, in proxy
        args, kw)
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/common/openerplib/main.py", line 117, in proxy
        result = self.connector.send(self.service_name, method, *args)
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/common/http.py", line 608, in send
        raise xmlrpclib.Fault(openerp.tools.exception_to_unicode(e), formatted_info)
    Server Traceback (most recent call last):
      File "/usr/lib/pymodules/python2.7/openerp/addons/web/common/http.py", line 593, in send
        return openerp.netsvc.dispatch_rpc(service_name, method, args)
      File "/usr/lib/pymodules/python2.7/openerp/netsvc.py", line 360, in dispatch_rpc
        result = ExportService.getService(service_name).dispatch(method, params)
      File "/usr/lib/pymodules/python2.7/openerp/service/web_services.py", line 586, in dispatch
        res = fn(db, uid, *params)
      File "/usr/lib/pymodules/python2.7/openerp/osv/osv.py", line 167, in execute_kw
        return self.execute(db, uid, obj, method, *args, **kw or {})
      File "/usr/lib/pymodules/python2.7/openerp/osv/osv.py", line 121, in wrapper
        return f(self, dbname, *args, **kwargs)
      File "/usr/lib/pymodules/python2.7/openerp/osv/osv.py", line 176, in execute
        res = self.execute_cr(cr, uid, obj, method, *args, **kw)
      File "/usr/lib/pymodules/python2.7/openerp/osv/osv.py", line 164, in execute_cr
        return getattr(object, method)(cr, uid, *args, **kw)
      File "/usr/lib/pymodules/python2.7/openerp/addons/base/res/res_config.py", line 120, in action_next
        next = self.execute(cr, uid, ids, context=context)
      File "/usr/lib/pymodules/python2.7/openerp/addons/oecn_base_fonts/oecn_base_fonts_config.py", line 163, in execute
        new_font_rml  = '<setFont name="'+o.map_ids[0].name+'" '
    IndexError: list index out of range
