  4. Web-Client 5.0.2
Web-Client 5.0.2
24 帖子 5 发布者 34.8k 浏览 1 关注中
  • C
    C
    chengwenge
    5.0.3 (2009-08-21)
    Bug Fixed (major):
    * [FIX] graph crashed, if date value is empty.
    * [FIX] O2M popup (IE issue).
    * [FIX] validation problem in wizards.
    * [FIX] search widget (missing validation).
    * [FIX] don't show sidebar if target=new.
    * [FIX] process view popup.
    * [IMP] datetime validation (year out of range).
    * [FIX] Fixed graph view for unicode characters.
    * [FIX] Fixed `Graph View` when there is no data on y-axis (For OOCRM).
    For more complete bug fix history, please visit Launchpad.
    5.0.2 (2009-08-11)
    New Features:
    * Removed TurboGears & PyXML dependencies
    * [color=Red]Ported to CherryPy 3 + Mako template, almost 5-7 time faster then the previous version[/color]
    * Re-implementation of graph with Open Flash Chart 2
    * Implemented profiler for code profiling (for developer's only)
    * Implemented unit test api (for developer's only)
    * Implemented anonymous login
    Improvements:
    * Compatible with Python 2.6
    * start-openerp-web command is renamed to openerp-web
    * Improved cache system (efficiently handle per db cache).
    * Added min_rows, limit configuration options for M2M/O2M fields
    * Improved ListGrid button action (support act_url).
    * Implemented `Concurrency Exception` handling.
    * Database filter options from configuration
    * Login controller with custom template for small Ajax login screen
    * Strip the header completely for action with target=new.
    * New Picture widget (display only)
    * Improved wiki widget
    * Improvements in `Import/Export` (db_id, id, import compatible).
    Bug Fixed (major):
    * Concurrenry problem when inserting o2m values from popup.
    * Calendar view (improper day span).
    * Incorrect sequence number incrementation
    * Fixed long URI problem (relate links)
    * Fixed notebook widget (nested notebooks are not working)
    * Dynamic notebook page visibility with attrs.
    * Improved Ajax validator (fixes onchange problem when there is some invalid value in the form)
    * Prevent conflicts with `onchange` and `attrs/state change` hooks.
    * Month calendar issue (day span 3 instead of 2 for hours=16 with day_length=8)
    * M2M (listview reload) problem in wizards.
    * O2M popup rendering time is too slow (IE bug)
    * attrs (invisible) is not working properly on fields with labels
    * attrs is not working properly on Group widgets
    * Evaluate dynamic domain & context expression.
    * Search popup validation problem (bug #338141)
    * Ignore concurrency check if no check field defined.
    * Create custom field for custom object (o2m popup problem).
    • L
      L
      ldfoe
      这个问题解决了吗?
      我在本机测试,loading的时间比网络(demo.shine-it.net)的时间还长,想不通。
        [quote]原帖由 [i]ldfoe[/i] 于 2010-2-20 15:29 发表 www.shine-it.net/redirect.php?goto=findpost&pid=3955&ptid=606
        这个问题解决了吗?
        我在本机测试,loading的时间比网络(demo.shine-it.net)的时间还长,想不通。 [/quote]
        换用 Chrome 或者 FireFox 就好了...
        • L
          L
          ldfoe
          谢谢您的解答!
          但还有一个问题:偶用demo.shine-it.net,也是在IE中。
