  4. onchange装饰器具体是如何触发的?
2 帖子 2 发布者 1.0k 浏览
    dennis888
    写于 最后由 dennis888 编辑
    1.示例
    from odoo import models, fields,api
    class AModel(models.Model):
    _name = 'a.model.name'
    field1 = fields.Char()
    field2 = fields.Integer(string="an other field")
    @api.onchange('field1', 'field2') # 当这两个字段值改变时调用该函数
    def check_change(self):
    if self.field1 < self.field2:
    self.field3 = True
    2.api.py
    def onchange(*args):
    """ Return a decorator to decorate an onchange method for given fields.
    Each argument must be a field name """
    return attrsetter('_onchange', args)
    def attrsetter(attr, value):
    """ Return a function that sets attr on its argument and returns it. """
    return lambda method: setattr(method, attr, value) or method
    The following attributes are used, and reflected on wrapping methods:
    • method._onchange: set by @onchange, specifies onchange fields
    • method.clear_cache: set by @ormcache, used to clear the cache
    On wrapping method only:
    • method._api: decorator function, used for re-applying decorator
    • method._orig: original method
    WRAPPED_ATTRS = ('module', 'name', 'doc', '_constrains',
    '_depends', '_onchange', '_returns', 'clear_cache')
    INHERITED_ATTRS = ('_returns',)
    1. 问题:
      请问当'field1', 'field2'字段值发生变化时,是如何触发调用装饰器函数的?_onchange 是fields类的一个内部方法吗?可是在api,fields和models里都没找到哦,哪位大牛能帮解答一下?谢谢
    • 静静静 离线
      静静静 离线
      静静
      在js 里面找吧。。。
