  4. 使用odoo-bin scaffold 生成的默认模块 点击升级时候报错 版本odoo12
7 帖子 2 发布者 1.7k 浏览
    llrrjj
    错误:
    Odoo Server Error
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 757, in parse
    self._tags[rec.tag](rec, de, mode=mode)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 662, in _tag_record
    record = model.with_context(rec_context)._load_records([data], self.mode == 'update')
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\models.py", line 3805, in _load_records
    records = self.create([data['values'] for data in to_create])
    File "", line 2, in create
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\api.py", line 452, in _model_create_multi
    return create(self, arg)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\base\models\ir_actions.py", line 58, in create
    res = super(IrActions, self).create(vals_list)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\models.py", line 3506, in create
    records = self._create(data_list)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\models.py", line 3606, in _create
    cr.execute(query, params)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\sql_db.py", line 148, in wrapper
    return f(self, *args, **kwargs)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\sql_db.py", line 225, in execute
    res = self._obj.execute(query, params)
    psycopg2.IntegrityError: 错误: 在字段 "activity_user_type" 中空值违反了非空约束
    DETAIL: 失败, 行包含(240, demoTwo server, ir.actions.server, null, null, action, 1, 2018-12-28 01:44:38.993237, 1, 2018-12-28 01:44:38.993237, ir_actions_server, code, 5, 218, null,
    action = {
    "type": "ir.actions.act_window",
    ..., null, null, null, null, null, null, null, null, null, null, null).
    During handling of the above exception, another exception occurred:
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 654, in _handle_exception
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 312, in _handle_exception
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\pycompat.py", line 87, in reraise
    raise value
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 696, in dispatch
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 344, in _call_function
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\service\model.py", line 97, in wrapper
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 337, in checked_call
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 939, in call
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\http.py", line 517, in response_wrap
    response = f(*args, **kw)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\web\controllers\main.py", line 966, in call_button
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\web\controllers\main.py", line 954, in _call_kw
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\api.py", line 749, in call_kw
    return _call_kw_multi(method, model, args, kwargs)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\api.py", line 736, in _call_kw_multi
    File "", line 2, in button_immediate_upgrade
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\base\models\ir_module.py", line 71, in check_and_log
    return method(self, *args, **kwargs)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\base\models\ir_module.py", line 596, in button_immediate_upgrade
    return self._button_immediate_function(type(self).button_upgrade)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\addons\base\models\ir_module.py", line 535, in _button_immediate_function
    modules.registry.Registry.new(self._cr.dbname, update_module=True)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\modules\registry.py", line 86, in new
    odoo.modules.load_modules(registry._db, force_demo, status, update_module)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\modules\loading.py", line 417, in load_modules
    force, status, report, loaded_modules, update_module, models_to_check)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\modules\loading.py", line 313, in load_marked_modules
    perform_checks=perform_checks, models_to_check=models_to_check
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\modules\loading.py", line 222, in load_module_graph
    load_data(cr, idref, mode, kind='data', package=package, report=report)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\modules\loading.py", line 68, in load_data
    tools.convert_file(cr, package.name, filename, idref, mode, noupdate, kind, report)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 801, in convert_file
    convert_xml_import(cr, module, fp, idref, mode, noupdate, report)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 864, in convert_xml_import
    obj.parse(doc.getroot(), mode=mode)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 754, in parse
    self.parse(rec, mode)
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\convert.py", line 763, in parse
    exc_info[2]
    File "E:\ODOO\v12\Odoo 12.0\server\odoo\tools\pycompat.py", line 86, in reraise
    raise value.with_traceback(tb)
    odoo.tools.convert.ParseError: "错误: 在字段 "activity_user_type" 中空值违反了非空约束
    action = {
    " while parsing file:/e:/odoo/v12/odoo%2012.0/server/addons/demo_two/views/views.xml:27, near
    demoTwo server
    code
    action = {
    "view_mode": "tree,form",
    "res_model": self._name,
      @llrrjj 在 使用odoo-bin scaffold 生成的默认模块 点击升级时候报错 版本odoo12 中说:
      报错信息提示了,既然有非空约束,是不是应该给个默认值。
        llrrjj
        刚用这个 不怎么懂 我这代码拿错了
        demoOne server
        code
        action = {
          在 回复了 llrrjj 最后由 编辑
          @llrrjj
          你现在拿的这个是odoo关于server action的代码。你用这个想要实现什么功能?
          上述贴出来的代码跟报错没有直接关系吧,我觉得应该找那个字段在的model。
          L 2 条回复 最后回复
            llrrjj
            在 回复了 hui 最后由 编辑
            @hui
            model中没有报错那个字段的
            class demo_two(models.Model):
            _name = 'demo_two.demo_two'
            name = fields.Char()
            value = fields.Integer()
            value2 = fields.Float(compute="_value_pc", store=True)
            description = fields.Text()
            @api.depends('value')
            def _value_pc(self):
                self.value2 = float(self.value) / 100
              llrrjj
              在 回复了 hui 最后由 编辑
              @hui
              这还是用 odoo-bin scaffold 这个生成的代码 都没有改过
                在 回复了 llrrjj 最后由 编辑
                @llrrjj 看那个字段在哪个model中啊,看看那个model中的代码
