  4. 论坛发送邮件验证码失败
论坛发送邮件验证码失败
已定时 已固定 已锁定 已移动 已解决 Odoo 新手求助
2 帖子 2 发布者 1.3k 浏览
  • 托 离线
    托 离线
    托尼
    odoo13后台已经正确配置了邮件的收发参数,且已经验证正常,然后我在论坛模块注册新用户后点击邮件验证就会出现以下错误
    我怀疑是发送账号的问题,于是我用另一个账号的邮箱接收和发送又产生另一个错误
    Odoo Server Error
    File "/root/odoo-ls/src/odoo/odoo/addons/base/models/ir_mail_server.py", line 526, in send_email
    smtp.sendmail(smtp_from, smtp_to_list, message.as_string())
    File "/usr/lib/python3.6/smtplib.py", line 867, in sendmail
    raise SMTPSenderRefused(code, resp, from_addr)
    smtplib.SMTPSenderRefused: (501, b'Mail from address must be same as authorization user.', '[email protected]')
    During handling of the above exception, another exception occurred:
    File "/root/odoo-ls/src/odoo/addons/mail/models/mail_mail.py", line 256, in send
    smtp_session=smtp_session)
    File "/root/odoo-ls/src/odoo/addons/mail/models/mail_mail.py", line 363, in send
    msg, mail_server_id=mail.mail_server_id.id, smtp_session=smtp_session)
    File "/root/odoo-ls/src/odoo/odoo/addons/base/models/ir_mail_server.py", line 536, in send_email
    raise MailDeliveryException(
    ("Mail Delivery Failed"), msg)
    odoo.addons.base.models.ir_mail_server.MailDeliveryException: ('邮件发送失败', "通过SMTP发送邮件失败 'None'.\nSMTPSenderRefused: 501\nMail from address must be same as authorization user.\[email protected]")
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 624, in _handle_exception
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 310, in _handle_exception
    File "/root/odoo-ls/src/odoo/odoo/tools/pycompat.py", line 14, in reraise
    raise value
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 669, in dispatch
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 350, in _call_function
    File "/root/odoo-ls/src/odoo/odoo/service/model.py", line 94, in wrapper
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 339, in checked_call
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 915, in call
    File "/root/odoo-ls/src/odoo/odoo/http.py", line 515, in response_wrap
    response = f(*args, **kw)
    File "/root/odoo-ls/src/odoo/addons/website_profile/controllers/main.py", line 283, in send_validation_email
    request.env.user._send_profile_validation_email(**kwargs)
    File "/root/odoo-ls/src/odoo/addons/website_profile/models/res_users.py", line 58, in _send_profile_validation_email
    self.id, force_send=True, raise_exception=True)
    File "/root/odoo-ls/src/odoo/addons/mail/models/mail_template.py", line 523, in send_mail
    mail.send(raise_exception=raise_exception)
    File "/root/odoo-ls/src/odoo/addons/mail/models/mail_mail.py", line 262, in send
    smtp_session.quit()
    File "/usr/lib/python3.6/smtplib.py", line 984, in quit
    不知道哪里有问题 有没有可以参考的配置?
    digitalsatoriD 1 条回复 最后回复
    • digitalsatoriD digitalsatori 从 中的 GoodERP 专区 移动了该主题
      在 回复了 托尼 最后由 编辑
      @托尼 因为你的邮箱服务器不支持Emai Relay所以不能发送验证用户以外的邮件。
      可以安装这个模块来解决你的问题: https://apps.odoo.com/apps/modules/13.0/mail_outbound_static/
      • digitalsatoriD digitalsatori 将这个主题转为问答主题,在
      • digitalsatoriD digitalsatori 将这个主题标记为已解决,在
