  3. Odoo 安装指南
  4. Etiny的安装
Etiny的安装
已定时 已固定 已锁定 已移动 Odoo 安装指南
11 帖子 5 发布者 17.8k 浏览
    ooop
    想玩玩eTiny,看来不太容易,按照tiny官方网站的安装说明书,出现如下错误,谁给看看!多谢!
    [code]~$ tinyerp-client
    ~$ wget www.turbogears.org/download/tgsetup.py
    --20:17:20-- www.turbogears.org/download/tgsetup.py
    => `tgsetup.py'
    正在解析主机 www.turbogears.org... 67.15.84.19
    正在连接 www.turbogears.org|67.15.84.19|:80... 已连接。
    已发出 HTTP 请求,正在等待回应... 200 OK
    长度: 15,517 (15K) [text/plain]
    100%[====================================>] 15,517 27.46K/s
    20:17:25 (27.39 KB/s) - `tgsetup.py' 已经保存 [15517/15517]
    james@u-server:~$ python2.4 tgsetup.py
    TurboGears Installer
    Beginning setuptools/EasyInstall installation and TurboGears download
    Downloading cheeseshop.python.org/packages/2.4/s/setuptools/setuptools-0.6c6-py2.4.egg
    File "tgsetup.py", line 435, in ?
    tg_main()
    File "tgsetup.py", line 188, in tg_main
    main(args)
    File "tgsetup.py", line 361, in main
    egg = download_setuptools(version, delay=0)
    File "tgsetup.py", line 342, in download_setuptools
    src = urllib2.urlopen(url)
    File "/usr/lib/python2.4/urllib2.py", line 130, in urlopen
    return _opener.open(url, data)
    File "/usr/lib/python2.4/urllib2.py", line 358, in open
    response = self._open(req, data)
    File "/usr/lib/python2.4/urllib2.py", line 376, in _open
    '_open', req)
    File "/usr/lib/python2.4/urllib2.py", line 337, in _call_chain
    result = func(*args)
    File "/usr/lib/python2.4/urllib2.py", line 1021, in http_open
    return self.do_open(httplib.HTTPConnection, req)
    File "/usr/lib/python2.4/urllib2.py", line 996, in do_open
    raise URLError(err)
    urllib2.URLError: [/code]
      holts
      我装2.5的很正常啊
        ooop
        [code]~$ start-tinyerp.py
        /usr/lib/python2.4/site-packages/CherryPy-2.2.1-py2.4.egg/cherrypy/lib/profiler.py:54: UserWarning: Your installation of Python doesn't have a profile module. If you're on Debian, you can apt-get python2.4-profiler from non-free in a separate step. See www.cherrypy.org/wiki/ProfilingOnDebian for details.
        warnings.warn(msg)
        File "/usr/bin/start-tinyerp.py", line 5, in ?
        pkg_resources.run_script('eTiny==1.0rc2', 'start-tinyerp.py')
        File "/usr/lib/python2.4/site-packages/pkg_resources.py", line 448, in run_script
        self.require(requires)[0].run_script(script_name, ns)
        File "/usr/lib/python2.4/site-packages/pkg_resources.py", line 1166, in run_script
        execfile(script_filename, namespace, namespace)
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/EGG-INFO/scripts/start-tinyerp.py", line 24, in ?
        from tinyerp.controllers import Root
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/controllers.py", line 49, in ?
        from tinyerp import subcontrollers
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/subcontrollers/init.py", line 1, in ?
        import actions
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/subcontrollers/actions.py", line 47, in ?
        from form import Form
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/subcontrollers/form.py", line 46, in ?
        from tinyerp import widgets as tw
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/init.py", line 1, in ?
        import form
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/form.py", line 722, in ?
        from action import Action
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/action.py", line 39, in ?
        import screen
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/screen.py", line 43, in ?
        import tinycalendar
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/tinycalendar/init.py", line 1, in ?
        from widgets import DayCalendar
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/tinycalendar/widgets.py", line 43, in ?
        from base import TinyCalendar
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/widgets/tinycalendar/base.py", line 47, in ?
        from tinyerp.tinygraph import choice_colors
        File "/usr/lib/python2.4/site-packages/eTiny-1.0rc2-py2.4.egg/tinyerp/tinygraph/init.py", line 33, in ?
        from matplotlib.numerix import arange
        File "/usr/lib/python2.4/site-packages/matplotlib/numerix/init.py", line 82, in ?
        import numpy
        ImportError: No module named numpy[/code]
          安装numpy包
          [code]
          sudo apt-get install python-numpy
          [/code]
            ooop
            这个 状态是启动了?
            warnings.warn(msg)[/code]
              ooop
              在tony的耐心帮助下,终于搞定etiny,应tony的要求发几张图给大家看看!
              [attach]20[/attach]
              [attach]21[/attach]
              [attach]22[/attach]
              • ? 离线
                ? 离线
                游客
                不错,不错。真的不错!
                  mopewolf
                  解决过程呢?!写下来分享一下!
                    ooop
                    按照官方网站的安装说明就好了!
                    [检测到链接无效,已移除]
                      meum
                      感觉界面没有客户端的友好
